hop
showcrop
04-06-2008 12:58:31
how do you avoid rear wheel hop? it seems to really cut into my traction.
jd b puller
04-08-2008 18:21:10
 Re: hop in reply to jd b puller, 04-06-2008 12:58:31
That's easy, just put it in first gear...or maybepull 2 plug wires off, it should get rid of the hop.
Sorry, us 2 cylinder guys don't know what 12-15MPH is.
When you are getting the "hop" where's the nose? Up in the air, or planted on the ground?
Drew
04-08-2008 19:54:01
 Re: hop in reply to jd b puller, 04-08-2008 18:21:10
That wont even cure it. I've seen a 2-cyl at 3.5 MPH turn into a basketball, more than just a couple times, too.
Barnheater
04-07-2008 19:50:09
 Re: hop in reply to showcrop, 04-06-2008 12:58:31
Try shortening your hitch, move it closer to rearend.
Farmall 47
04-06-2008 14:15:02
Are you talking about pulling? I'm not sure I've heard of wheel hop in pulling, how fast are you running?
showcrop
04-06-2008 14:47:10
 Re: hop in reply to Farmall 47, 04-06-2008 14:15:02
Hi probably 12- 15 mph, I've seen it happening to others too
Life of Riley
04-06-2008 14:56:00
 Re: hop in reply to showcrop, 04-06-2008 14:47:10
How much air pressure are you running and at what weight are you pulling?
Life of Riley
04-06-2008 16:33:25
 Re: hop in reply to Life of Riley, 04-06-2008 14:56:00
Also, what kind of tires? Could be several things causing it.
