Want to buy dyno
LloydE
04-05-2008 20:22:49
Looking for a used dyno for sale within 600 miles of Minneapolis. Phone 763-286-5595.
jd b puller
04-06-2008 12:22:14
 Re: Want to buy dyno in reply to L.D.W., 04-05-2008 20:22:49
Try the classifieds. Also call Keith Merfeld, in IA. 563-582-8710. He DID have one for sale, not sure if it still is or not.
buickanddeere
04-06-2008 11:33:48
 Re: Want to buy dyno in reply to LloydE, 04-05-2008 20:22:49
HP and rpms?
Do you have standby electric power?
A pto powered generator costs less than a most used dyno's. Just connect a couple of old forced air electric furnaces that are a dime a dozen in scrap yards.
No water hose connections or high pressure oil leaks that a dyno requires.
And have the equpment so your lights on while everybody else is sitting in the dark.
Normally I scold people for posting ads in a discussion area rather than on the classified ad section but it's Sunday and I'm in a good mood.
New to JD
04-06-2008 17:08:55
 Re: Want to buy dyno in reply to buickanddeere, 04-06-2008 11:33:48
Noticed your post reply. What exactly are you saying? Is there a way to compute HP using a generator?
JUDY
04-06-2008 17:56:28
 Re: Want to buy dyno in reply to New to JD, 04-06-2008 17:08:55
No but I believe there is a way to compute his (her) ignorance.
buickanddeere
04-06-2008 23:11:04
 Re: Want to buy dyno in reply to JUDY, 04-06-2008 17:56:28
"Judy" once again shows it"s lack of useful data.
With a resistive load which the hot air furnace is. It"s just volts X amps/746. And add about 5 HP to spin the generator/fan and provide rotor excitation. Judy couldn"t get through that kind math either, too complicated.
