Spark Plugs???
JD NUT
04-04-2008 06:52:22
Have done a lot of work on a JD G to make a solid puller. Have not pulled the tractor since any work was done to it, but I'm not sure what I should use for spark plugs and how to determine the heat range to use? I've heard the Autolites are good plugs to use. I know you want as cold of plug as possible without any fouling out problems, obviously.
LN
04-04-2008 20:14:54
 Re: Spark Plugs??? in reply to JD NUT, 04-04-2008 06:52:22
The ac C88L plugs have always seemed to work best for me
Life of Riley
04-04-2008 20:41:32
 Re: Spark Plugs??? in reply to LN, 04-04-2008 20:14:54
I was running C88L and C87 AC's for a while, but then they changed the design on them. Now the spacer between the nut and the threads is about half as thick, and it lets the nut sink down into the block to where you can't get a wrench or socket on it to tighten or loosen it. I ended up getting the adaptors from R.E.A.M. Corp (http://reamproducts.com/) so I could run the new style plugs.
buickanddeere
04-04-2008 16:03:46
Autolite 3116 or 478's. AC C88L or Denso 3020. Change the wires to solid core. You don't want resistor plugs or wires on your tractor.
770 Puller
04-04-2008 20:21:24
 Re: Spark Plugs??? in reply to buickanddeere, 04-04-2008 16:03:46
Spiral core wires, are they considered to be resistor wires?
buickanddeere
04-07-2008 09:31:17
 Re: Spark Plugs??? in reply to 770 Puller, 04-04-2008 20:21:24
They would be inductive rather than resistive. What do they measure with an ohmmeter?
Dangerous
04-04-2008 09:31:38
I DONT KNOW IF ITS CUZ THERE GREEEN BUT CHAMPION D-23'S OR AUTOLITE 388'S HAVE GIVEN ME THE BEST PERFORMANCE. I KNOW THEIR ARE CRTITICS ABOUT CHAMPIONS BUT THATS MY 02 CENTS. DEPENDING ON YOUR FUEL GRADE AND SPARK, GAP WILL RANGE.
HAVE A GREAT TIME PULLIN!
