spark plug adapters for two-cylinder deere's
JD NUT
04-02-2008 19:23:59
Can anyone tell me where I can find spark plug adapters for two-cylinders so you can run modern spark plugs? Allows you to put in the smaller diameter thread spark plugs of today. I have seen them advertise, but can't remember where. I thought it was the Green Magazine, but went through a couple of the magazines and couldn't find it. If any knows where I can order these it would be great. Looking to put them in a JD G puller.
buickanddeere
04-03-2008 11:01:12
 Re: spark plug adapters for two-cylinder deere's in reply to JD NUT, 04-02-2008 19:23:59
Autolite 3116, AC Delco C88L or Denso 3020. All non resistor plugs that ae resistant to fouling.
Over rich idle mixture, too cold engine coolant and extended idling cause plug problems.
long hauler
04-02-2008 19:48:12
the green mag i have it is in april 2007 r.e.a.m. RICHARDSON ENGINEERING AND MACHINING PO BOX 311 NEW LOTHROP MI 48460 B 989-743-9148 C 989-277-0141 $5 EACH PLUS $3 SIPPING HOPE THIS HELPS
