Pulls July 4th thru 7th. Sou. IN, IL, North KY
SPT
06-24-2002 05:46:59
Any pulls over July 4th weekend, southern IN,IL, northern KY. Uncut tires 3-4 MPH.
Thank you,
SPT
dcpuller
06-24-2002 18:10:48
 Re: Pulls July 4th thru 7th. Sou. IN, IL, North KY in reply to SPT, 06-24-2002 05:46:59
Tractor pull at Casey Il. July 4 at 1pm farm stock classes 45-8500lb 3mph., uncut tires ,10%rpm, wheelybars. must use wheel wts. on back front wts. no more than 24" in front of tractor. Also have 35-85 cut tire and 5000 and 6000 any gear.
SPT
06-25-2002 12:07:23
 Re: Re: Pulls July 4th thru 7th. Sou. IN, IL, North KY in reply to dcpuller, 06-24-2002 18:10:48
What about belly weights and drawbar length and height?
Shawn
06-25-2002 19:42:55
 Re: Re: Re: Pulls July 4th thru 7th. Sou. IN, IL, North KY in reply to SPT, 06-25-2002 12:07:23
Hello,
In the farm classs, you can only have wheel weights and front weights, no belly weights, and no hanging weights on the back, and no weights stuck under the seat.
the drawbar has to be original, all mounting brackets and everything, but you can have a custom clevis, plow loop or just a twisted clevis, and it is at 18 inches high.
hope this helps
Shawn
