Farmall M
mhankc
03-31-2008 09:28:29
I have a 50 M that has a 4" bore, stepped head m&w pistons, SM-450 cam, stock stroke, and a 400 head. My 2 questions are, what spark plug should I be using, and is this enough change to the engine that I will need to open up the carb.
ChadS
03-31-2008 10:42:28
 Re: Farmall M in reply to mhankc, 03-31-2008 09:28:29
Put up of shut up is what I got told this week in my path of enlightenment, its catchy!! Come on! put up or shut up,, I got money with your name on it, so you gonna put up? I say your full of $hit on not keeping the curves right in the venturi. ChadS
ChadS
03-31-2008 10:38:28
OK, sell me one then. How much? Ill put it to the test. Can I come down and pick it up? Ive heard that BS before on that subject,,, last time, they got proved wrong. Chad
ChadS
03-31-2008 09:59:52
Autolite 386 or 3116 one or the other,,, And yes, you will have to open up the jets and find a proper size venturi for your application. If its over 170 psi, Id be looking for a 29, and a 27. the 29 for higher rpm, and the 27 for best low end torque. Hope this helps, ChadS [email protected]
mhankc
03-31-2008 10:02:54
 Re: Farmall M in reply to ChadS, 03-31-2008 09:59:52
This 27 venturi...probably a dumb question, but do I just go to an IH parts store and ask for one, or what did they used to come in? I guess, what I'm asking, is was that a standard part in another tractor or ????? Thanks
ChadS
03-31-2008 10:23:29
 Re: Farmall M in reply to mhankc, 03-31-2008 10:02:54
You will find a 27 in a Super M, you will find the 29 in later 450's and some 656 IH tractors. All the basic part numbers are the same,,, just have different ID bores. I make em from scratch,,I have a full set, custom made from smallest to biggest, and then, some bigger yet,,,, look at the bottom on the venturi,, in the ID of the venturi, thats where you should find the 2 digit number that tells you what it is,,, just like the smart guy said,,, its in 32nd's divide the top number into the bottom number (32) and will give you the actual dimentions. ChadS
Smarter than ChadBS
03-31-2008 10:13:51
The "27" means 27/32 (.8438). A 29 venturi is 29/32 (.9063). Get a 15/16 (.9375) drill bit or turn on a lathe. Drill the main jet out to .093. Adjust on a dyno.
ChadS
03-31-2008 10:19:14
 Re: Farmall M in reply to Smarter than ChadBS, 03-31-2008 10:13:51
Hey smart guy! More to it than just runnin a drill bit thru em,,,,you have to keep the natural curves into em when ya drill em,,, takes me a day to do one up right. AND,,, there is another 10 hp if you cut em just right,,,, but Im not tellin. You figure it out. Who r u anyways? You knowmy name, and so far, your still here,, may as well introduce yourself, pull up a chair and do what ya ust did for this fella!!! You helped him out! See!!! wasnt hard was it?
Smarter than ChadBS
03-31-2008 10:26:31
 Re: Farmall M in reply to ChadS, 03-31-2008 10:19:14
Wrong again. No curve needed and I can prove it on a dyno.
Lean from ChadBS..... Stay in school
ChadS
03-31-2008 10:25:29
Oh smart guy,,, please stop using my name in your handles,,, be original and use your own name if ya can. Thank you. ChadS
ChadS
03-31-2008 11:04:43
 Re: Farmall M in reply to ChadS, 03-31-2008 10:25:29
Darn modern view. They dont put the posts in the right order!! Hey smart guy!!! I got the cash you got the parts? Wanna trade for the governor spring??? My spring will make more than your venturi. Take me up on it? Chad
ChadS
03-31-2008 11:06:34
 Re: Farmall M in reply to ChadS, 03-31-2008 11:04:43
Not for sale huh? I knew your so full of it your eyes are brown.
mhankc
03-31-2008 11:06:24
Thanks for the info and tips. You two have fun. Must be a rainy day. ha ha ha
ChadS
03-31-2008 11:07:58
 Re: Farmall M in reply to mhankc, 03-31-2008 11:06:24
yeah it is. LOL!! Ive got to get some shipping done today! Lots of stuff goin out! Sorry this got hijacked and went how it did. Chad
