MM 800 in a GBD or G6
dan osborne
03-25-2008 19:47:10
I found a MM 800 power unit that I want to put in a tractor. It is not an HD as it has 4212 heads on it. Would this make a good swap and what would it take? It has a mag on it and a V-belt set up where the starter would go. Currently it is set up to run on natural gas. Is there a carb avaliable or should I go to propane? What about an oil pan/oil filter? Should I hold out for an HD? Any advice would be much appreciated. Thanks!
Mopower
03-31-2008 13:13:23
 Re: MM 800 in a GBD or G6 in reply to dan osborne, 03-25-2008 19:47:10
If you can get a deal, hold out for an "HD". It has better heads and it's slightly different. Better engine.
long hauler
03-26-2008 17:33:25
if you want to sell the engine as a power unit .i can sell it for you so they cant run a belt system at a furniture shop. thanks or if you have a smaller power unit on natural gas that works.
helpful advice
03-26-2008 06:57:05
The one thing i know is that a moline runs better on propane than on regular gas and u probably want to wait for that HD 800 before you do your eingine swap.
