WC pulling engine parts
jhb
03-25-2008 18:02:44
What D-17 engine parts will fit in a WC block or what modifications need be done to allow them to fit?
MLPANKEY
03-26-2008 19:05:03
 Re: WC pulling engine parts in reply to jhb, 03-25-2008 18:02:44
Most clubs allow the d17 block swap for wc or wds. if youre dead set on the 201 block youll have to use a wd 45 crank instead of the d17.
why?
03-26-2008 18:56:54
why does everyone have to hide what they have, step up to the plate and pull what ya have not what your hiding
Kip-Utah
03-26-2008 06:17:52
Rods[but WC,WD,WD45 are the same, camshaft[same profile as earlier W models], pistons[lower compression than stock if you don't use a WD45 crankshaft], note...a 45 crank & D17 crank are the same except the D17 has larger main journals,so wont fit a WC block, but 45 crank will drop right in. You can use the manifold,carburator, distributor, & governor assembly off the 17 to your advantage. Kip
pullerboy88
03-25-2008 18:10:21
just put the d-17 motor in your wc and be done with it. If you don't want to do that i know a guy in ky that will be abel to help you out.
jhb
03-26-2008 05:49:32
 Re: WC pulling engine parts in reply to pullerboy88, 03-25-2008 18:10:21
Won't the D-17 engine be very noticeable as different than a WC engine both looks and part numbers? I thought that I would not be stock with the D-17 engine in place and be disqualified.
stock?
03-26-2008 14:17:13
 Re: WC pulling engine parts in reply to jhb, 03-26-2008 05:49:32
Check you local rules. Some clubs look at the D-17 block as "manufactures recommended replacement", while others will put you in Div. 3. It is easy to tell the two blocks apart, but the d-17/E3 block will bolt right in.
