valve springs for farmall M
ES
03-25-2008 16:39:49
Looking for heavyer valve spring for a M any automotive spring that might fit thanks for any help
ChadS
03-29-2008 06:16:53
 Re: valve springs for farmall M in reply to ES, 03-25-2008 16:39:49
Looked at the inner spring set on a double spring small block chevy too! For a IH 300 head. For my setup, too stiff of spring,,, will wear cams fast. On a full with cam lobe with a good grind might be good for something close to stock cams,,, and allow for a bit more valve movement. good time to reface the lifters, and maybe go look for that puller grind camshaft!!
Ed Hodge
03-26-2008 15:55:21
small block chevy
FarmerSid
03-28-2008 04:54:56
 Re: valve springs for farmall M in reply to Ed Hodge, 03-26-2008 15:55:21
Ed. Do you mind being a little more specific.
Thanks!
Sid
