Tire Cutting
Learning2Pull
03-18-2008 19:13:46
I've heard the terms top cutting and front cutting.. they sound pretty self explanatory. Is it feasable for an individual to cut his own tires with a disc grinder, and if so, how long would it take and how should he go about it? I have a set of 38" tires for my M with about 90% tread on them.
ben brown
03-21-2008 20:01:48
 Re: Tire Cutting in reply to Learning2Pull, 03-18-2008 19:13:46
yes on the back is a jig so that all cuts are the same. evey type tire has to have it own jig. differt makes take different jigs also, this is a special made tire cutting machine. not to many of them around. i got it from a guy who had it special made. there a lot more to this machine then is showing in the pic. hard to explane excatly how it works. but does a real good job. can also do v cut. using a long bar short bar tire.
ben brown
03-21-2008 17:24:21
i cut tire with a machine. now it take time to do it right and is a dirty job but do enjoy doing it. the pic is of a tire 151 top and front cut. before you pick them up there cleaned third party image
algar
03-19-2008 19:26:32
I have been using a bosch hand held planer ,no smoke
jdfarm
03-21-2008 19:34:17
 Re: Tire Cutting in reply to algar, 03-19-2008 19:26:32
Do you have a jig or anything? Could you give me some info on how you do it. Thanks
FarmerSid
03-19-2008 06:57:10
40 hrs! Holy Crap! That's alot of rubber to chew off. Do you have a pattern of some sort that you lay on the tire lug to get each lug as close as possible?
Cheers!
Sid
ChadS
03-19-2008 15:43:09
 Re: Tire Cutting in reply to FarmerSid, 03-19-2008 06:57:10
My first pair of tires I ever cut, at the time, they were the only tires I had so I took my time, 8hrs a day, was a very hard casing, bars like concrete,,, But shaped them with a 7 inch dresser wheel, then took the 4 inch finish wheel and cut the front lugs out, then after a few runs, seen where they were gripping onthe bar on the dirt, and cut a little more to get a good bar on the ground. 4 inch grinder was the time consumtion, but did a good job. Best pair of sand tires I ever seen. Chad
oliver77
03-19-2008 06:09:22
You can cut them with a grinder but believe me it is one of the nastiest jobs you will ever do. Not to mention it is a pretty good workout.
Rwolfejr
03-19-2008 05:37:08
These tungsten carbide rubber grinding wheels will do a nicer job a lot quicker.
www.saburr-tooth.com
johndeereman
03-18-2008 19:54:26
yes you can and it takes awhile like 4 hours per tire
Old Time puller
03-19-2008 01:38:04
 Re: Tire Cutting in reply to johndeereman, 03-18-2008 19:54:26
If you have 90% tread, its gonna take a lot more than 4 hrs per tire to do it right.
ChadS
03-19-2008 06:48:16
 Re: Tire Cutting in reply to Old Time puller, 03-19-2008 01:38:04
I had 40 hours in this pair of 15.5X38's!! They do seem to grip well, even in sand. ChadS
