stock jd A w-straight 6 speed
long hauler
03-17-2008 19:51:45
well pullers i have been reading about people saying a stock jd A with straight 6 sp would pull good. does anyone have personal experience with an A pulling. as far as i can see it has had nothing done but i put a petronix in it and i thing i am going to have to take the generater of and go to a 12 volt alti. it pops back when you give it gas then revs up. thannks for the info
52 A Puller
03-20-2008 20:36:31
 Re: stock jd A w-straight 6 speed in reply to long hauler, 03-17-2008 19:51:45
I got a stock 52 JD A that I pull with. It has 13.6 X 38"s tires and spins out before it should. Mine has the straight 6-speed not the high/low. it will make a good pulling tractor. I pull in 5500 lb. antique class. It runs strong just spins out and I am using cast rear wheels. My air pressure runs between 6-10 p.s.i. 6 for the sand tracts and 10 for the really hard tracts. I plan on changing to pressed steel.
HossinMe
03-18-2008 17:42:00
Yep,I got the dual range tranny but there aint no 5th or 6th gear in er. I think it may of come from factory with steel wheels. Those tractors didnt have 5th and 6th gear.Ive got a new weapon for this yr ive been working on for a year,830com Case diesel.Gonna give a certain M that I built a run fer tha trophy! Later Hoss Yes I ran at skow and farmington too. is this bob or bill?
1958johndeere620
03-18-2008 18:30:24
 Re: stock jd A w-straight 6 speed in reply to HossinMe, 03-18-2008 17:42:00
I don't think either one of them do the computer thing.I pull the single front wheel 620.
HossinMe
03-18-2008 17:02:25
Hey longhauler,I have been pulling with my 47jda with wide front in stock antique class for 3yrs now.6spd.I mostly use low gear and have whooped 880 oliver diesels and farmall Ms.I use real hot plugs and open load screw up bout 1/2 turn from normal.Have 16.9 38 tires and will stall tractor at times.Bout 6lbs air press.Run in 5500 and 6000 lb class,sometimes 6500 depending on track. Good Pulling,Hoss
1958johndeere620
03-18-2008 17:26:44
 Re: stock jd A w-straight 6 speed in reply to HossinMe, 03-18-2008 17:02:25
Hoss,,
I don't you have the duel range tranny?
I remember you stalled her in Skowhegan.
1958johndeere620
03-18-2008 17:30:34
 Re: stock jd A w-straight 6 speed in reply to 1958johndeere620, 03-18-2008 17:26:44
That is , Don't you have the dual range tranny?
Somebody
03-18-2008 19:16:30
 Re: stock jd A w-straight 6 speed in reply to 1958johndeere620, 03-18-2008 17:30:34
I thought he said he had a striaght 6, not a dual range.
dual range is- 1-2-5 in low side, 3-4-6 in high side.
The straight 6 has no high or low.
Not trying to say somebody is wrong, down here in Kentucky where I live we might just use different terminology than yall.
BushogPapa
03-17-2008 20:33:03
Could be it is slightly "Lean", or the spark is weak..which could even be caused by fouled plugs.. You might try opening the adjustment for the power a click or 2 and see if it is better, if not, set it back and try the idle mixture setting a click or 2 farther open and try that.. ONE click off, and they will either blow smoke, or hesitate... In Antique Farm Stock, you may be competitive, but there are plenty who have added a few goodies that are hared to detect..! Your stock 6 speed A will pull anything the tires will allow, in 1st gear..!
Ron.
long hauler
03-18-2008 17:16:33
 Re: stock jd A w-straight 6 speed in reply to BushogPapa, 03-17-2008 20:33:03
thanks yall i think i will con my bother into making wheelly bars and weight brakets and give it a try. it has 12.4 38 press rims on it. prbably will spin out though.
