No1 Powerblock for A JD.
Jeremy Brault
03-15-2008 19:23:25
Anyone know of anyone in the minnesota area that can fix a powerblock. I got one that I was gonna have bored out and they bored the doughnut outta the front of the block. I believe that some one good can build a doughnut and bevel it and weld it back in and then plain it flat. After that they would need to weld the sleeve in. thanks
Drew
03-16-2008 20:37:02
 Re: No1 Powerblock for A JD. in reply to Jeremy Brault, 03-15-2008 19:23:25
You will spend more $ fixing what you have than buying another block. If you go welding sleeves into your block, there is a chance it will leak. If you go welding a sleeve in just one side, the heat and expansion/contraction from welding may screw up the O-ring seal in the other bore. At that point you need to weld sleeves into both sides. That is going to run you about $1100-$1200. If you want to start over w/ another 6-1 block, email me.
Did the shop boring the block crash the boring bar into the top of the block, or did they have a retard moment and intend on boring the top of the block?
RRWisehart
03-16-2008 05:01:48
1-402-265-42217
