tires
jdfarm
03-14-2008 17:29:32
Does anyone think a 60 john will hook up with a good set of sharp 23' 13*6 tires on a 14 inch rim somewhere around the 5500 lb class?
bobidan23
03-15-2008 12:25:21
 Re: tires in reply to jdfarm, 03-14-2008 17:29:32
the tires will probably work well for you but i think 5500 is too light for a 60 more like 6500 to 8000 if its "stock"
jdfarm
03-15-2008 17:02:11
 Re: tires in reply to bobidan23, 03-15-2008 12:25:21
It has extensive head and valve work with m and w high comp pistons. It weighs 4840 with a 150 pound driver. About the lightest 60 ive ever seen.
1958johndeere620
03-14-2008 18:31:59
I wouldn't put a 13 6 on a 14 inch rim. A 15 5 is about the same height as a 13 6 and it would fit better. I bought 16 9's and mounted them on 14 inch rims. They are about 4 or 5 inches taller then the 13 6's and the 15 5's so beware of the major change in final gear ratio change due to increased height. If you plan on pulling in second gear the 16 9's will be to much on a stock 60. I have stalled my 620 out in second gear on a bitting track.
jdfarm
03-14-2008 19:09:24
 Re: tires in reply to 1958johndeere620, 03-14-2008 18:31:59
I have a different opinion. By putting a 13.6 on a 14 inch rim you are spreading the tire out which means putting more lug on the ground.
1958johndeere620
03-14-2008 19:12:01
 Re: tires in reply to jdfarm, 03-14-2008 19:09:24
Point well taken.
jdfarm
03-14-2008 19:16:15
 Re: tires in reply to 1958johndeere620, 03-14-2008 19:12:01
They are a very hard set of kelly springfield tires. Ive never had any experience using that brand so I dont know what they will do.
1958johndeere620
03-14-2008 19:21:07
 Re: tires in reply to jdfarm, 03-14-2008 19:16:15
Do you think they will fold up at low pressure or are the to hard? I took my 13 6 and put them on my farmall 300. Works well on that tractor.
LONG HAULER
03-14-2008 17:42:41
I USED 13.6 ON MY JD G AND SPUN OUT. HAD TO GO 15.5 AND GAINED 25 FEET.
