Which to build?
hunter 1
03-13-2008 19:12:26
I have a 1939 JB B and A 1937 JD A.
What to build one of them into a puller. The class choices are 3500 4500 5500lbs.
For the 37A I have a heisler head for it, also have a 44 a for parts ( if any can be used)
For the 39 B I have a 5-2 power block was told that it will bolt in. And drill bottom holes
Any have late b for parts( if any can be used)
So I what to build some power,
don"t what to build the biggest tractor out there,
What to stroke it,one that will not require me to move the camshaft.What it to last, will be running stock rpms.
Who is a good persomn to have my crankshaft work done by, what kind and lenght of rods, pistons?
Welcome any and all commits ideas and suggestions
jd b puller
03-14-2008 07:22:08
 Re: Which to build? in reply to hunter 1, 03-13-2008 19:12:26
hunter1, both have good potenial in the div III arena.
On the B, if you use the 5-2 PB, you'll need to get a later B head (preferably a Heisler), your 39 head won't work. Suggest boring the PB to 5.125", pushing it ahead a little bit and using 5.125" Lycoming (320) pistons. You can cut an offset dome on them and poke it into the head end of the PB. Stroke it to 7.25" - use Waukesha 320 rods on big end, IH Diesel on the little end. Will give you decent power (right around 300 cubes), built very tough (2.625" rod journals vs the "normal" 2.3" Farmall 300 rods).
I've had Keith Merfeld do quite a few crankshafts for me, rods too - 563-582-8710.
