PL Manifold
Kevin Bonwell
03-13-2008 04:53:20
Hello,
Looking for a LP manifold for C-301 International engine. Will pay top dollar for one in good shape.
ChadS
03-14-2008 14:47:09
 Re: LP Manifold in reply to Kevin Bonwell, 03-13-2008 04:53:20
Carb off a 715 combine,,, part number 534932r91 If this is in a 460/560 it will sit in the correct direction as the 560/460,,, if its on a 706-856 it will sit backwards,,, or the air inlet facing the front of the tractor. But, its one mean carburator for under 3000RPM. If you get one or have one,, open the main jet size out to .110 and get rid of the electric shut off,, and install a manual load screw and packing from a M carb or something like that. try to find a #33 and a 35 venturi,,,, the ID numbers are a 2 digit number located on the bottom of the venturi, on the inside of the bore,,,, a 33 will be good for lower rpm torque,, and the 35 is a good all around venturi size to run. Hope this helps,,, I have 2 of these carbs available custom built if you cant find one. ChadS Email is [email protected]
ChadS
03-14-2008 05:43:52
 Re: PL Manifold in reply to Kevin Bonwell, 03-13-2008 04:53:20
Kevin, if you have a good stock manifold, you can separate them, and cut the intake manifold down, and have one in about a day, with only time spent on it. Where the two halfs bolt together,, its like a cast box that engulfs the intake,,, simply take a cut off saw blade in a hand held grinder and go cutting. cut as much of the cast box as you can and youll find the almost the exact manifold. Only real differece in the two, (other than the LP is a separtae manifold,) is the flange port where the carb/throttle body bolts up, the port is a little bigger onthe LP manifold,,, maybe .060 bigger. I did this to a 263, before, it never frosted up at the carb flange, after, the whole manifold frosted like I had nitrous or something!! But Id say it dropped the incomming air temp a good 15 degrees. Hope this helps, ChadS [email protected]
Kevin Bonwell
03-14-2008 10:32:40
 Re: LP Manifold in reply to ChadS, 03-14-2008 05:43:52
Chad,
Thanks for the help. May do just that. What carb. do you suggest I use on the C-301.
