HEISLER CYLINDER HEAD
WENDEL
03-11-2008 13:40:27
DOES ANY ONE KNOW WHAT YEAR JD B A HEISLER HB357 WILL FIT THANKS FOR ANY HELP.
tbuzzard
03-11-2008 19:14:53
 Re: HEISLER CYLINDER HEAD in reply to WENDEL, 03-11-2008 13:40:27
fits all unstyled B's
jd b puller
03-11-2008 15:53:59
 Re: HEISLER CYLINDER HEAD in reply to yankee2, 03-11-2008 13:40:27
Wendel, try posting a picture of the front/back. There's guys on here that can pick one out from 20 feet away... Or if you have a head gasket, compare, 41-52 were all the same gasket. 39/40 was a little different, and unstyled different yet.
Hot Rod A
03-11-2008 23:44:40
 Re: HEISLER CYLINDER HEAD in reply to jd b puller, 03-11-2008 15:53:59
I don't remember which number goes to which year breaks off hand, but simply putting it, if the head has a cast protrusion which will stick into the cylinder, then it will fit all Bs with a 4 speed trans, and if it has two indentations into the head for each cylinder, one above and one below the valves, then it will fit all Bs with the 6 speed transmission, both hi/lo and creeper straight 6.
