Tires
Luke Olson
06-19-2002 20:30:21
i am building an oliver 88 pulling tractor and i am wondering, what size tires would be the best 34 inch or 38 inch. thanks for any help. luke
TimC
06-20-2002 13:09:25
 Re: tires in reply to Luke Olson, 06-19-2002 20:30:21
It all depends on the motor. If you are close to 600 cubic inches then you might be able to turn 18.4 38s over if you are pulling open classes, (any rpm, 5th gear). If you are pulling first or second gear then you still might be ok with a smaller engine.
Mike
06-20-2002 07:33:48
20.8 34's will work fine and are cheaper to pick up used. my 2 cents
Go with the 38's
06-19-2002 21:01:16
