Kill switch
Slo
06-19-2002 19:47:15
I am going to use a trailer break away switch for a kill switch. I wired one side of the switch to the hot side of the coil, and grounded the other side. This is a normally open switch, which closes the circuit when the break away is pulled.
Didn't work. What am I doing wrong? Do I need to splice into the hot wire of the coil instead of wiring to the hot post on the coil?
Thanks in advance.
Hypermax1066
07-01-2002 04:57:29
 Re: Kill switch in reply to Slo, 06-19-2002 19:47:15
You just showed everyone here how stupid you really are! Thanks for proving what an idiot you are.
Slo - thanks fellas
06-20-2002 18:53:06
It works now. Thanks for your help.
Chances R
06-20-2002 04:59:37
Slo, I took the hot wire that goes to my coil off. Then ran a hot wire to the switch, and then from the other side of the switch go to the coil.
Chances R
06-20-2002 16:24:29
 Re: Re: Kill switch in reply to Chances R, 06-20-2002 04:59:37
Sorry Slo, I had forgoten how those switches work. In my case, I was using a different type of sitch (normally closed) and it worked great for me.
Killed them all
06-20-2002 04:24:15
You hook one wire to ground. The other wire goes to the coil, the same post that the distributor wire hooks to.
redhead
06-19-2002 20:30:56
Slo, be careful! If you provide a ground for the hot wire going to the coil, a dead short is created. If it's not fuse protected, you'll let the smoke out of some things you don't want too. Good luck.
Winner
06-19-2002 20:08:01
The only way it will work is to control the power to the coil. Splice into the coil hot wire.
TimC
06-20-2002 13:13:14
 Re: Re: Kill switch in reply to Winner, 06-19-2002 20:08:01
Then it wouldn't start. The switch is normally open. Shorting the ground side of the coil out will kill it.
