4.250 piston
LN
03-08-2008 17:15:10
Where can you buy a 4.250 piston for a farmall M and any idea abouthow much $
54SMTA Puller
03-09-2008 09:13:56
 Re: 4.250 piston in reply to LN, 03-08-2008 17:15:10
Call me at 660-265-5915
turbos10
03-08-2008 20:01:23
I bored mine to 4.25 and kept the same stroke with factory rods. I am running a set of flat tops from Murphy's Motor service and paid about $500 for them. They were cut from Aries blanks and are very light weight for such a large piston.
Jeff at Murphys should have the demensions on mine. Email you and I can give you more info on what to tell Jeff so he can pull up the part.
Charles E. McNelly
03-09-2008 07:29:25
 Re: 4.250 piston in reply to turbos10, 03-08-2008 20:01:23
Hey Chris, Ever get that Cummings going in your truck?
turbos10
03-11-2008 13:18:37
 Re: 4.250 piston in reply to Charles E. McNelly, 03-09-2008 07:29:25
Yep, It has been up and running several months now. I ended up with a full manual 4L80 behind it. Got it fueled up where it is nice to drive now and I am lovin" it.
Jeff Garst
03-08-2008 19:32:59
Chevy Big Block pistons are 4.25, you can get them with a big dome, You have to lengthen the rods or stroke the crank.
jd b puller
03-08-2008 17:44:05
 Re: 4.250 piston in reply to family tradition, 03-08-2008 17:15:10
Sorry, carried the 1 one too many times.. $500 not $600.
jd b puller
03-08-2008 17:32:40
 Re: 4.250 piston in reply to Hillbilly Hooker, 03-08-2008 17:15:10
LN said: (quoted from post at 21:15:10 03/08/08) Where can you buy a 4.250 piston for a farmall M and any idea abouthow much $
I can make you new ones of whatever you want. Tell me what you need for CH, Pin dia, dome, valve relief, etc. Around $600
[email protected]
