Oliver 77 trans input shaft
Doug, OH
03-04-2008 08:07:54
While tearing down my tractor I noticed the coupler and input shaft splines are just about gone. To the point that the only thing holding was the eyebolt. The tractor is being built to pull. Can I replace with stock parts and will they hold up? Where is a good source for my trans. parts??
Thanks, Doug
RichB
03-05-2008 11:05:15
 Re: Oliver 77 trans input shaft in reply to Doug, OH, 03-04-2008 08:07:54
Yes the stock parts will hold up fine,I run about 150 HP and have not had a failure yet.Just make sure you use good bolts and check them OFTEN. Rich
lucky sevens
03-04-2008 10:29:57
I have been pulling a 77 with about 65hp for 6 years on the stock shaft and coupler with no problems. the coupler and shaft should be avalible at owosso tractor parts in owosso,MI. PH# 989-729-6567
