1940 JD B Weight Loss
Gary from Mules
03-03-2008 16:36:53
If I replace the power troll with a flat back, how much weight will I loose. The tractor weighs 3,250 lbs. with mo on it. I would to get down to 3,000 or a bit less. I posted this on the JD sight and all I got was ridiculed from some guy. Just need some info, not looking to do anything real drastic here, I only go to two or three pulls a year. Thanks in advance.
Hot Rod A
03-05-2008 16:30:19
 Re: 1940 JD B Weight Loss in reply to Gary from Muleshoe, 03-03-2008 16:36:53
Get a split pedestal. You only need the top half that bolts to the frame, not the bottom half that has the spindles on it. Then, find the bottom bolster and hubs from an M/MT. They will bolt right onto the bottom of a split pedestal with little or no grinding, just as long as you use some socket head bolts as opposed to regular hex head bolts. The MT bolsters have much lighter hubs and a lot less cast, and your rims will bolt right onto the M hubs. Few people would even notice the difference, and it will function just fine. That should drop you another 50lbs or close to it. You could also unbolt the entire air cleaner assy from the radiator, there is a lot of dead weight there and for pulling you won't need it, just a filter or something off of the air pipe on the carb, and should you want to use the tractor for farm work at a later date, you can always just bolt it back on.
Also, you don't need the rear end filled to the rated capacity with oil, as long as there is some in there, and you're just pulling it, you can get by with about half. After that, then you're starting to get into more extreme measures like cutting some things, weld-on hubs, etc, these were just the simple wrenching losses.
Jim Johnson
03-04-2008 18:42:36
Gary you would lose 100 LBS. a friend has a flat back if you want it. $100.00. Let me know if you want it.
Jim
Gary from Muleshoe
03-05-2008 04:33:28
 Re: 1940 JD B Weight Loss in reply to Jim Johnson, 03-04-2008 18:42:36
I guess I will pass, it won't take enough off to get me down where I need to be. I can't see anything else I can take off to get the weight down. I already have disk wheel on the rear. I am looking to sell it or trade it for an MM Z or U.
