chads got me thinking on compression
mlpankey
03-01-2008 10:47:21
after reading chads post . i realiize that my thinking of staying under 18.1 is wrong . wondering now what a d17 with 30.1 static compression will do after all they are basically a restrictor plate engine. with the small intake and updraft carb.
ChadS
03-02-2008 08:27:26
 Re: chads got me thinking on compression in reply to mlpankey, 03-01-2008 10:47:21
Put a deck plate on it, set the cyl pressure by the thickenss of the plate, thicker would be less pressure, thinner would be more. How thick??? dont know,,, ChadS [email protected]
mlpankey
03-02-2008 14:54:24
 Re: chads got me thinking on compression in reply to ChadS, 03-02-2008 08:27:26
thanks chad i can figure compression ratio . dont need a deck plate .
ChadS
03-03-2008 04:47:26
 Re: chads got me thinking on compression in reply to mlpankey, 03-02-2008 14:54:24
My old engine, came out to 14.25 to 1 this time around, 12.5 to 1. Only thing is the same on this one is the crank and cam,,, everything else, was built/rebuilt to match up. Poured in the hard block just yesterday, closer,,,, closer,, to hearing it run!! Im anticipating 250 psi of cyl pressure. No orings, with water, No milling of the head either,,,, Shooting for 110hp at rated rpm, and way under 300ci. Sounds doable doesnt it?? ChadS [email protected]
mlpankey
03-03-2008 07:18:21
 Re: chads got me thinking on compression in reply to ChadS, 03-03-2008 04:47:26
should show higher than that on a gauge . unless restricted greatly for air or alot of overlap .
mEl
03-02-2008 04:17:11
The size of the gear reduction starter required to turn it over will put you up at least two weight classes, add the weight of the super high voltage CDI and Special designed Ign coil to force the spark between the electrodes at that compression ratio, And you will probably have to figure a way to girdle the spark plugs to keep from stripping the threads out of the head, and the cost of having VP design a fuel for that CR!!!!! ----- there may be some real technical issues to overcome!!!!! !
mlpankey
03-02-2008 09:08:14
 Re: chads got me thinking on compression in reply to mEl, 03-02-2008 04:17:11
mel chad saw one run at 130.1 static thats what a d17 is with only the volume of a head gasket like he posted earlier . im only looking at half that much . but dont underestimate the spark energy of msd.ever figure what the compression ratio is on them alky tractors with four chargers are when there spun up.
ChadS
03-01-2008 17:04:54
Imagine the cam overlap on that baby!! WHEW! may as well drill petcocks in the sides and leave em open while its running. Put little igniters right there, shoot fire out it. :twisted: ChadS
ChadS
03-01-2008 14:43:42
I did not build it from the start, it was brought to me like that. It went BOOM!!! thats what happened. ChadS
mlpankey
03-01-2008 14:57:58
 Re: chads got me thinking on compression in reply to ChadS, 03-01-2008 14:43:42
yep id say 130.1 static would go boom . but half of that shouldnt you think.
