safe oil level in a m rear end
eric in wi
02-25-2008 19:25:09
how low can u run a farmall m transmision and rearend with oil without ruining the bearings and gears any help would be appreciated thanks eric
Joe H.
02-26-2008 19:08:09
 Re: safe oil level in a m rear end in reply to eric in wi, 02-25-2008 19:25:09
Depends how hard your turnin it speed limit probably get buy with just a little open gear would be another story also depends on how heavy your pullin it electric pump is a good idea if weight is the real problem
billklump
02-26-2008 08:15:37
i run mine with the oil at the bottom of the pto plate been thinking of lovering it to 2 gallons and ading a eltrec oil pump and lube system would like to hear other opions thanks bill
