farmall front end
matt34
02-24-2008 20:15:07
i have a farmall 300 with the factory narrow front. does anyone know of any 5 or 6 bolt hubs that will work on the factory spindles? has anyone make a front end? if so what has worked and where did you get your hubs?? thanks
CGpuller
02-26-2008 07:21:59
 Re: farmall front end in reply to 39 IH, 02-24-2008 20:15:07
I have been told that 300 utility hubs are a direct bolt on but can't verify it. I built a light weight lower bolster for my H by useing a pedestal from a B or C farmall. This reguires modification to the mounting plate. The B/C pedestal has a removable plate that the spindles are mounted on. I made a new bottom plate with 1 1/16 boat trailer spindles and matching 4 bolt wheels, all available at your local farm supply store. This saved about 120 pounds compared to the factory setup.
lbm
02-25-2008 17:29:08
 Re: farmall front end in reply to matt34, 02-24-2008 20:15:07
You might look around your area at a truck supply company first. I made mine using 3 inch heavy wall pipe with a 1/2 inch plate for the bolster went to tractor supply purchased 5 lug trl.hubs and 1750lbs. spindles,set the spindles true in the pipe weld together at a 5 degree angle . using a 5 lug pressed steal wheel you have a front bolster,hope this helps
