stainless exhaust valves
RichB
02-16-2008 12:52:49
Any one know If stainless valves can be found with a stem diameter of .372 overall length of around 5.00 and a head diameter of 1.395 Thanks Rich
jason pohlman
02-17-2008 22:07:14
 Re: stainless exhaust valves in reply to RichB, 02-16-2008 12:52:49
if you have acess to a lathe use chrysler 340 valves. they are 1.6 but can be turned down with little effort.a little long at 5.075 but that can be made up by shimming the spring to get the installed height where it needs to be.they are also the right stem diameter. i used some valves from an a-460 bbf head last summer on a popane head for an h.a little work on the lathe and all was good! hope this helps you out.
