gear reduction starter oliver 880
Ed Hodge
02-15-2008 15:54:52
for every oliver puller out there like me with big cube motors and big hp the stock starter wont turn the motor over i found the starter you need it a delco starter you can get right a napa your a starter and alternator rebuild shop the number of the unit is (1113275) it works real well bolts right up with no problums will not fit under the side panels you will have to cut in out.
Cody
02-17-2008 19:34:22
 Re: gear reduction starter oliver 880 in reply to Ed Hodge, 02-15-2008 15:54:52
28MT Delco-Remy. It is a very poular starter. There is two diff styles. One of them has the selnioid on top of the starter and will clear the side panel. You local starter shop should be able to fix you up with one with the right bendix. If you have no luck, drop me an email.
fly on the wall
02-17-2008 16:52:41
keep searching there is a delco starter that will fit under the side pannels
