Propane carb and regulator?
Mr.Moline
02-15-2008 12:05:46
Is an Impco 200 an alright carb to run on my tractor? Also what regulator are most MM pullers running?
LW
02-15-2008 17:34:56
 Re: Propane carb and regulator? in reply to Mr.Moline, 02-15-2008 12:05:46
Depends on how "big" the "tractor"? Century regulator are cheaper and work nice and more tuning springs are available for the regulators. Also whick 200? S,D or T?
Mr.Moline
02-16-2008 12:44:32
 Re: Propane carb and regulator? in reply to LW, 02-15-2008 17:34:56
The engine is about 650 cu in. As for the carb I"m not sure which model it is or even what to look for on the carb that would tell me if its an s d or t Thanks
LW
02-17-2008 18:39:54
 Re: Propane carb and regulator? in reply to Mr.Moline, 02-16-2008 12:44:32
If your able to turn some rpm the 200D will wrok nice if it close to stock rpm I'd go with the single or the century carb. The 200s will bolt to peterson's manifold. We really need to know more to elaborate
moline puller
02-17-2008 09:25:24
The 200D is a daul diaphram one on each side of the carb and it is a four bolt pattern where it bolts to the intake and 200T is a triple diaphram. The 200s is a single,two bolt carb.More than likely you will need the 200D for this is the one I had ran on my four cylinder with around the same cubic inch.Also I don't know what rpm you are running as I ran 4,000rpms or better.Send me an email if you want and I can give you my number if you'd like.
