1150 Massey ?s
casey Kyarsgaar
02-13-2008 17:49:46
We are building a 1150 to pull with and are trying for 6500 pound class we have heard a super 90 rearend will bolt up does anyone know if it will and what the weight diffrence would be
Casey Kyarsgaard
02-20-2008 11:39:16
 Re: 1150 Massey ?s in reply to casey Kyarsgaard, 02-13-2008 17:49:46
no it is an 1150 we can take off all the hydrolics three point new front end aluminum front grill we are almost there already just need a few more pounds
8970
02-15-2008 11:11:27
Can be done. Look at the pictures of the Gordyville pull in the NA class. The one with orange wheels has not had excessive work done. The one that won the class has had alot of grinding done and can get below 5500 lbs.
Casey Kyarsgaard
02-21-2008 11:27:38
 Re: 1150 Massey ?s in reply to 8970, 02-15-2008 11:11:27
do u know if it bolts right up or if u have to do machining to get it to work
8970
02-21-2008 20:22:32
 Re: 1150 Massey ?s in reply to Casey Kyarsgaard, 02-21-2008 11:27:38
I do not know about the 90. The 1150 and 1155 I have seen do it with the orginal rearends and transmissions.
heavy!
02-14-2008 13:35:04
a 6500 lb 1150? you need to loose nearly 10,000 lbs! You didn't mean a 150 MF did you!
