ChadS
02-16-2008 07:23:50
Re: Torque in reply to Lil Red, 02-13-2008 13:47:55
High manifold vacuum comes with cyls with high pressure, and in low rpm, 2000 and under rpm,, keeping the speed of the incoming air at a faster pace or enhanced pace. Overlap is a compesation for octane. Deflating the cyl pressure so it will run at high rpm,, say 5500 and up. Would a naturally aspirated V8 turning 8000 rpm, hold all day long with 250 psi of cyl pressure? No. I dont think it would,,, for long,, so they let that incoming air in the port escape to not let so much air in at the time the valve opens. LOW rpm you have all the time in the world to fine tune that air, and they can hold together if they can ignite the fuel even with high cyl pressures. Low rpm engines I would imagine would have a stronger vacuum signal,,, VS a high rpm,, or say it had more velocity,, or turbulent,, IH cams,,, pushed the intake valve timing, to do just what you described,, best explained,,, is the air charge the piston created then the valve opens is at a higher rate. Takes a harder toke off the intake/carb. Keeps the mean gas speeds higher at the low rpms,, keeping the air mixed with the fuel, and showing an increase in low end pulling torque. Thats what seen in IH upgrades,,, from say like the Super M all the way up to the C-301. Strokers with long rods and super fast piston speeds,, will have a tremendous amount of air speed, and shoot, take an ollie 88 head,, or a 560 IH head,,, take a good short block and an even better cyl head, that makes a good cyl pressure, and have a cam profile,,, say ollie 88 with a IH c-301 cam grind profile,, (not exact,, but a starting point) see what is seen,,, if technology is needed,, its already out there,, its over 40 years old. Tractors,, like the ollie 77-88, or the 560, or any 6 cyl engine back then, wanst much on port or valve size,, and thats why so much can be increased with alot of cyl head work to flow the air they are capable of moving. No, I dont have a flow bench,, just a die grinder with alot of stones. LOL! one thing in common with the two,,, with the big carbs, and the rpm,, niether one of em lug very hard under 1800 rpm,,, but the ones with the smaller carb setup have real good low end torque. Not increased,, but stronger,,, spring in the step, peppy!! They got torque in the low rpm cause the air is moving faster. JMO2. Chad [email protected]
