70 DSL
KB
05-06-2001 18:54:38
WIll a 70 diesel make a good puller for stock class? IF so, what makes it or what are the tweak items for getting the most out of a 70? What needs to be done for "more than stock" classes?
KB
G Taylor
05-07-2001 20:56:32
 Re: 70 DSL - ???? in reply to KB, 05-06-2001 18:54:38
The 70D didn't oil the center bearing as well as the 720D/730D. The 720/730 had larger valves & improved breathing. The late 720 Blackdash & 730 had more durable pistons & head. The six hole injector tips had a better pattern depending on who you ask. How deep are your pockets? A 720/730 are 75HP machines with dry airfilter conversion,a straight exhaust stack & full fuel rack at 1150rpm. If valve springs are good, may approach 100HP at 1500rpm.
