Will Massey 44 hubs bolt right onto a Farmall M?
PH
02-10-2008 18:55:57
Have a Farmall M that i would like to put duals on for parades. I have several sets of pressed steel rims that I can use, but i need a 9 bolt hub. I know the axle diameter is the same, but do you have to modify the keyway at all? Or will they bolt right on. My friend has a set he will give me if they will work.
Ed Hodge
02-15-2008 02:47:03
 Re: Will Massey 44 hubs bolt right onto a Farmall M? in reply to PH, 02-10-2008 18:55:57
oliver 88 hubs will fit
bm3501466
02-13-2008 15:22:40
When the 44 came out, the local massey dealer challenged my uncle to a demonstration plow match. It was his Farmall MD vs their new 44. As soon as they dropped the plows in the ground the hub on the massey broke. That is all I have to say..... .
farmallguy46
02-11-2008 16:31:33
if you pull 5500 or less id saw youd be fine, if your a heavy puller find a set of m&w hubs with the triple u bolts. i broke one last year at 5500 lbs with 18.4's and a wet clay track, running tall gears. pop'd it coming out of the hole getn tires spinning
Pete1468
02-11-2008 15:29:19
They work just fine until they break. I"ve seen a couple sets break and have heard of several. These were on pulling tractors and just had pressed steel rims to lighten it up.
54supermta
02-11-2008 15:20:59
i put a set on superm had to machine the keyway to make them fit i broke them at a pull id find ones that are made for farmall m
farmallguy46
02-10-2008 19:51:53
yep will work
