Copper Head Gasket Question
F20Puller
02-10-2008 15:03:15
I was wondering what most people use to help a copper head gasket seal. Thanks in advance
Doug Boll
02-11-2008 11:09:13
 Re: Copper Head Gasket Question in reply to F20Puller, 02-10-2008 15:03:15
wire o-rings!!!
ChadS
02-11-2008 06:37:27
Patience is the best tool used. During the time the copper coat is curing, once its good n tacky,, just set the head on,, tighten the bolts/studs at 30 ft lbs and walk away for the rest of the day. Next day,, tighten the bolt.nuts torque within 10 ft lbs,, leave it sit for another 2-3 hours,,,, pour in the water,,, with the spark plugs out,, see if any leakage is present in the cyl, or in the crankcase,,, if not you can move on,,,
go ahead and torque the bolts to spec,,, fire it up and let it idle for about 10 minutes,, and shut it down and recheck for leaks,, go back and check the bolt torques, but DO NOT over torque them,,, try to keep within the stock realms of the book specs for your make and model.
The reason for letting it sit overnite is to let the glue, cure and harden in the nooks and cracks under a little pressure from the 30ftlbs of torque. lets it squish in and not expel the glue too soon,,, let it setup and dry,,, give it a chance to do its job. Hope this helps,, ChadS
Bendee
02-10-2008 16:13:10
A thin film of grease on all gaskets,if both surfaces are true it will seal after torque.
Festis
02-10-2008 15:33:28
we use copper plus, its like silicon, put it on block and head, rock and roll. have had good luck with it
Steve W.
02-10-2008 15:11:47
I like to put on a very thick coat with copper gasket seal, let it dry until tacky, and the spray it again with another thick coat. When I torque the head down I like to see that the copper is seeping out between the head and the block.
