9 bolt hub for ihc h
wildman from mo
02-08-2008 19:55:36
Does anyone know if there is a hub that will fit an h farmall axle without to much machine work ? massey,oliver,minn,john derre or others.I need your help as I don't want to use weld-on hubs if I don't have to .Building a 5 1/2" motor with lp head an want to go to tin wheels. Thanks for any help. I have a set of oliver 66 hubs i was trying to use on a super c but to much machine work . Wildman.
wildman from mo
02-10-2008 19:16:41
 Re: 9 bolt hub for ihc h in reply to wildman from mo, 02-08-2008 19:55:36
Steve il has a set of mm Z hubs for me.Thanks again for everyone's input.Wildman
CGpuller
02-08-2008 22:01:18
Oliver 77 hubs are the correct diameter. I have a set on my H. They only have one key which is fine, but it is too wide to fit the H. I narrowed the key with a grinder fitted with a narrow cut-off wheel.
wildman from mo
02-08-2008 20:19:49
I will measure the axle tomorrow.would like to find a light set of hubs to buy reasonable.Thanks for your input so far.Wildman
matt34
02-18-2008 16:28:35
 Re: 9 bolt hub for ihc h in reply to wildman from mo, 02-08-2008 20:19:49
i have a set of 9 bolts hubs off of an oliver 77 that will fit. let me know if you are interested.
Lil Red
02-08-2008 20:06:49
Do you need a one made for a keyed axle? If so what's the axle size?
haird7
02-08-2008 20:05:49
You can use Oliver 77 hubs. I am building a 350 right now and I have a set of 77 hubs in the mail somewhere. I have also heard that hubs from a 44 massey will work.
HLW
02-09-2008 10:46:07
 Re: 9 bolt hub for ihc h in reply to haird7, 02-08-2008 20:05:49
We put 44 Massey hubs on our M. Would not fit H
wildman from mo
02-10-2008 09:15:13
 Re: 9 bolt hub for ihc h in reply to HLW, 02-09-2008 10:46:07
Thanks to all the info you posted for me.Tractor pulling is fun but more importantly the people you meet. 62 year old farmer & puller.See you at the track. Wildman
