OT....Aftermarket Truck Air Filters
MCL
02-08-2008 17:12:48
Looking at aftermarket air filters for my truck (like K&N or similar). What do you guys have and/or like? I have a 2002 Chevy HD 6.0 gas. Like a little more power but hoping to help gas mileage also. Thanks.
John M
02-10-2008 09:16:32
 Re: OT....Aftermarket Truck Air Filters in reply to MCL, 02-08-2008 17:12:48
read the link good!
Mark from WI
02-10-2008 07:00:58
Mine only had a Flowmaster with 1 in and 2 out. I know Chevy put 2 in and 1 out on their trucks so true duals is very easy. Put remember don't remove any oxygen sensors or converters because you will have the idiot lights come on and you will lose gas mileage which is kinda defeating the purpose of putting a filter and exhaust on.
Mark from WI
02-08-2008 23:56:55
I installed an K&N filter on my 98 1/2 ton Dodge with a 360 in it. The gas mileage got worse. My boss at the repair shop I was working at said that when the engine takes in more air that it has to go somewhere. He said that the filter would do no good unless I opened up the exhaust. So I did, I put 2.5 inch dual exhaust with a Flowmaster muffler on it. It instantly got 125-150 miles more to a tank full. I only installed a filter not an cold air kit. So that is my advice hope it helps. Beside those 6 liters sound pretty nice with duals on them anyway.
MCL
02-09-2008 04:28:55
 Re: OT....Aftermarket Truck Air Filters in reply to Mark from WI, 02-08-2008 23:56:55
Some type of exhaust modification is in the plan. Not sure what though. Are you talking true duals from the engine on back? Or does yours go into a single converter and muffler then "Y" into 2 tailpipes. I don't know how Dodge builds theirs.
Thanks.
sparkplug
02-09-2008 07:01:43
 Re: OT....Aftermarket Truck Air Filters in reply to MCL, 02-09-2008 04:28:55
i agree. if the engine is going to breath in more air, it should be able breath out more air as well.
an engines an air pump. the more air you can move faster, the better of your going to be in terms of performance.
