stock farmall m
Devin in PA
02-08-2008 14:12:20
what would be the better tire size to put on a stock farmall m to pull it in the 5000,5500,6000 lbs classes. I have 12.4/ 13.6/ and 15.5 tires.
KCfromPA
02-09-2008 09:29:38
 Re: stock farmall m in reply to Devin in PA, 02-08-2008 14:12:20
Best tire I have found are 14.9 X 38 Armstrongs. The set that I have been running for about 8 years are road cut. A 14.9 compared to a 15.5 has more surface area on the track. Also if you are pulling on a hard track the 14.9 will get a better grip by getting into the dirt rather than a 15.5 that might stay on top. With my tire set up I pull 5500, 6000, 6500 and sometimes 7000. I hardly never touch the air pressure in the tires. I normaly have 12 lbs. in them. Only time if track is wet with alot of bite. Then I might have 14 lbs. in them. Just my thoughts. Good luck.
Cliff S
02-08-2008 14:43:30
13.6 Is what i have on my 1939 M with 41 Hp and it dose well! Just stay in those classes and don't go higher or you will be low on Power in 1st gear!
long hauler
02-08-2008 15:42:03
 Re: stock farmall m in reply to Cliff S, 02-08-2008 14:43:30
GET FIRESTONE DEEP TREAD 15.5 THAT ARE WORE ALMOST OUT. I PUT NEW 15.5 ON MY STOCK FARMALL M TURNED RPMS UP 10% AND PULLED UP TO 7000LB AT 186 FT PULLING A 16000LB SLED. I ORIGINALLY HAD NEW 13.6 AND GAINED 50FT GOING TO A 15.5 TIRE. THE NEW TIRE WILL TRY TO DIG DOWN IN THE TRACK WHERE OLD TIRES WILL STAY ON TOP AND PULL BETTER.
