magic springs
stonerock
02-07-2008 12:56:45
need magic springs for farmall m so it will pull much more better. will the springs help my traction problem. i need better tires
stonerock
02-08-2008 19:35:38
 Re: magic springs in reply to stonerock, 02-07-2008 12:56:45
a lot of time went into chads springs to get it right i know i am the one selling hitches for farmall m on ebay it took me over a year to get this hitch right many tries this one works the best. out of my shop they sell for 250.00 350.00 installed on ebay i cant get a bid of 200.00 they have no idea what i went through to build a better hitch.
Improtant Info
02-09-2008 05:07:26
 Re: magic springs in reply to stonerock, 02-08-2008 19:35:38
Your hitch is illegal in ALL organizations. It attaches ABOVE the centerline of the rear axle and that is breaking the rules or CHEATING! Imagine that from an IH junk puller!
Mike n Mo
02-09-2008 06:50:39
 Re: magic springs in reply to Improtant Info, 02-09-2008 05:07:26
I thing you need to look closely at the hitch you are refering to. It appears to me that the drawbar attaches to the origional hook point under the belly of the tractor. The vertical support does attach to the PTO cover area, but doesn't appear (at least from what I can see from the pictures)that it is attached to the drawbar. It only has a pad on the top and bottom of the drawbar to to hold it stationary vertically. If the drawbar fails it should pull straight out and fall on the ground. If the vertical support fails the hitch should drop. The pictures don't show every angle, but this is what I see from them. Discliamer: I have nothing to do with selling this hitch, or even know the guy that does, but it looks like a good design. Mike
mlpankey
02-08-2008 14:47:56
no pun was intendeed by me to chad . i just thought the question asked was out there a little bit. springs and tires tied to magic oh well there is mystery oil who knows whats next.
NFMS BOUND
02-08-2008 11:07:50
I am looking forward to seeing ChadS booth there selling springs, clutch packs, copper head gaskets, to go along with dyno brochures. I'm sure that SoMeThInG WeIrDeR will be there, getting dyno-tuned at 540 rpms, holding steady at 42hp but with the spring it will go to 46! I have already heard that Roberts ordered springs for all of the Toys, so did Lustiks for the Bullet!
masseyharris333d
02-07-2008 19:58:05
the only people that are mad are the one"s thats secret to "winning" got told. The old timers don"t like it when the begginers are given information that they had to figure out by themselves!!
Dangerous
02-08-2008 06:15:35
 Re: magic springs in reply to masseyharris333d, 02-07-2008 19:58:05
Sounds like you have taken too many but whippins Grand-Pa! Maybe you need to sell popcorn at the events.
stonerock
02-07-2008 19:21:35
didnot mean to cause any trouble. i need to get springs from chads for my tractor. also need tires. first year pulling ended up 8th for the year not very good but i will still try. got power not enough tracton
Frankenstein JD-A
02-07-2008 18:40:44
No doubt that chads gets an "A" for effort. I will give the guy credit, he trys his best to help anyone. BUT.....his math is fuzzy at best; and his understanding (or lack thereof) of physics still puzzles me.
I'm talking about the times he says heavier pistons/rods HELP....OR....the time he made up his own math formulas for HP instead of using the real ones and wouldn't listen to anyone trying to explain it him.
Dangerous
02-08-2008 06:17:19
 Re: magic springs in reply to Frankenstein JD-A, 02-07-2008 18:40:44
I think i saw you on Jerry Springer.
3 Words
02-08-2008 07:56:36
 Re: magic springs in reply to Dangerous, 02-08-2008 06:17:19
I think that the fact that you would watch Jerry Springer is what makes you "Dangerous"
molinesam
02-07-2008 19:57:25
Hey Frankenstein, That was quite a discussion - most of it was over my head. One thing I do know is that I've seen LW's moline pull & it's one bad machine. My GVI in 3rd was no match for his 4th + 10% gear.
bigjohn 3
02-07-2008 18:09:58
Stonerock, I don't know you or ChadS but I find his post very helpful. His magic springs post was well written & showed excellent mechanical knowledgeable. Give the man a break. Thanks.
ollie 88
02-07-2008 17:23:47
I don't see the humor here. Are you trying to be funny?
mlpankey
02-07-2008 15:36:26
snake oil helps rpms and traction.
Jon Aller
02-07-2008 14:07:04
Good lord, climb up off of ChadS already.
At least he tries to offer real help to those who are new to the sport.
molinesam
02-07-2008 17:16:45
 Re: magic springs in reply to Jon Aller, 02-07-2008 14:07:04
I agree. I don"t know ChadS from Adam"s house cat, but I enjoy his post. He seems extremely knowledgeable and is most helpful. His critics are out of line. We can disagree without being disagreeable.
Charles E. McNelly III
02-07-2008 16:36:25
Well said. I know he has helped me with questions I have.
Charles
hmm
02-07-2008 19:39:28
 Re: magic springs in reply to Charles E. McNelly III, 02-07-2008 16:36:25
ya know Chad has helped lots of us, maybe a little or maybe a lot. You guys make a big deal about him trying to make money off these magic springs but when i asked him about springs he told me to go to tractor supply and match up a governor spring and to go to Napa and get the recurve kit. So whats the problem, his info is free and no one forces you guys to read it. Chad has helped me a ton on my project and hopefully with projects in the future.
John B. NE Ind
02-08-2008 12:35:35
 Re: magic springs in reply to hmm, 02-07-2008 19:39:28
Buy the springs that are known to work, or, buy your own and try and figure what "will" work. Seems like a no brainer to me. Either way, for pulling the springs being changed definatly help. I talked to the Ohio Gru [Denny] years back who sells parts and the only way he would give out any info was if you opened your wallet. Chad offers his opinion on what will work for pulling. Right or wrong, at least he's giving some guidence without $$$$$ signs in the reply.
BTW, I've not needed Chads service's since I've been into tractor pulling longer then he's been alive. I fist pulled a JD A at 12 yrs old in 1960. If I "were" new to pulling I would definatly have his telephone number handy.
Dangerous
02-08-2008 20:35:52
 Re: magic springs in reply to John B. NE Ind, 02-08-2008 12:35:35
I agree totally with you. As for Denny's, my experience is they are a bunch of arrogant rude people AND WAY OVERPRICED!!!!! !!!!! !!!!! !!!!! !!!!! !!!!Ive been pullin about the same amount of time as you sir. I appreciate people like Chad who are salt of the Earth!!! We need more of them!!!!
Old Puller
02-09-2008 04:45:15
 Re: magic springs in reply to Dangerous, 02-08-2008 20:35:52
We need more people like Chad, giving all the new pullers bad advice so we can beat them. Learn from Chad - STAY IN SCHOOL.
Dangerous
02-09-2008 10:11:49
 Re: magic springs in reply to Old Puller, 02-09-2008 04:45:15
You must be from New York.
