farmall m govenor and distirbutor drive
eric wi
02-06-2008 06:35:25
first ? i have a farmall m distributor drive and the bottom bolts will line up but the top bolts will not i was wondering if there are 2 diffrent distributor drives second ? what can i do to the stock govenor to make it respond better and get more power with out spending a lot of $$ any advice would be appreciated
thanks eric
ChadS
02-08-2008 05:13:06
 Re: farmall m govenor and distirbutor drive in reply to eric wi, 02-06-2008 06:35:25
3 words,,
go to the hardware. Before you do,, I want to tell you this,,,, think about how many years it took to find out what works. How much work we did to our equipment to do better competitively,, and if and only if a few years of work aint worth nothing, then by all means, go to the hard ware. I will not drop that price. ChadS
Tom'Bud'K
02-08-2008 07:06:31
 Re: farmall m govenor and distirbutor drive in reply to ChadS, 02-08-2008 05:13:06
"3 words" I guess Chad (denny JR) show have finished high school. That was way more than "3 words"
johndeereman
02-06-2008 20:26:14
i think hes being sarcastic on the spring just tie strap the spring you have so it dont stretch out but a warning this eliminates your gov from workin so dont run it wide open unless its under load or youll be bying a new engine
eric wi
02-06-2008 10:54:03
where can i get the parts for the govenor
eric wi
02-06-2008 10:53:58
superih
02-06-2008 09:41:23
An "M" and a Super M did have slightly different drive bolt patterns. Use a rat-tail file to oblong your holes a little.
3 words
02-06-2008 06:48:48
"Magic Governor Spring"
NewHpuller
02-06-2008 16:46:02
 Re: farmall m govenor and distirbutor drive in reply to 3 words, 02-06-2008 06:48:48
where can you buy a magic governor spring
3 words
02-07-2008 05:08:39
 Re: farmall m govenor and distirbutor drive in reply to NewHpuller, 02-06-2008 16:46:02
Just do a search on this forum for "magic governor spring". It's good entertainment
molinesam
02-07-2008 18:32:14
 Re: farmall m govenor and distirbutor drive in reply to 3 words, 02-07-2008 05:08:39
3 words, I found the springs post very helpful. What's the point of your post? I don't see that you added anything useful to this discussion.
3 words
02-07-2008 18:49:06
 Re: farmall m govenor and distirbutor drive in reply to molinesam, 02-07-2008 18:32:14
The point is to change the governor spring. The man wanted a cheap "fix"for the governor. I'm sure the one Chads sells makes the governor more responsive, but it must be "magic" to be worth what he sells it for. It's a $2 spring! I guess if you're too lazy to go to a hardware store to find one yourself, then you can pay him the $25-30 he wants for one.
