460 overheating fast!!!!!
Redsm
02-05-2008 17:25:28
460 farmall, diesel 282ci, proper size electric fan, 2 year old radiator, radiator never seen a feild, new 160-170 thermostat, full of coolant, has electric "auto meter" water temp gauge "works"
Tractor can be driven about 15 minutes and gets up two about 210-220 fast seems like!!! and pores coolant out the "overflow" tube Bigtime!!!!!
Tractor done this once befor but took thermostat out because i thought that was the problem, left it out and ran it for the time being till i got a new thermostat for it"done fine" slow about warming up, and just recently about 2 weeks ago put it in and is now back two the same thing. all stared one time when i changed coolant in tractor."last fall"
Any help would be appriciated,
Thanks
guido
02-22-2008 10:56:33
 Re: 460 overheating fast!!!!! in reply to Redsm, 02-05-2008 17:25:28
HEY REDSM
I would check the thermostat first.
Old slyle used to fail in the closed position.If that is the case it would make the engine overheat as you described.
New style fail in the open position. The thermostat is needed for proper coolant flow, if the engine is overheating taking it out will aggavate the condition, slower water flow.
You may have a water pump that has lost the inpeller and not pumping at all. Head gasket ,as the other post suggested is also a possibility. Guido.
supertiquer
02-09-2008 19:23:34
if you have the thermostat in correctly, you could possibly have a cracked head. when it was out, it may not have gotten warm enough or had enough pressure to open up the crack. I used to pull a 560 with a 282 years ago in the superstock division and had this problem all the time. after 2 years and going through 4 heads, I decided the color of the black smoke wasn't worth it and switched to a gas block and head and converted it to alcohol. I have a 282/301 diesel head that has been rebuilt by chapin that has never been on a tractor. It is for sale. Post a reply if you might be interested.
BushogPapa
02-06-2008 15:33:47
Maybe you should check the next time with the thermostat in a pan of hot water, with a thermometer, to see just when and "if" it really is opening..
Jeff Oliver
02-05-2008 20:59:27
If I'm reading this right it will not overheat with the thermostat out of the tractor but when you put it in it does it. As the man said before I would check and make sure it is not in backwards. Easy to do....
jd b puller
02-05-2008 19:19:24
Whenever something overheats fast, I start thinking head gasket. Don"t know much about these motors, is the injector in a spot that if you remove the injector, you can see the top of the piston? See if one of the pistons is clean.
M Hoffmann
02-05-2008 17:57:29
is the thermostat in the right direction, is the water pump ok have seen impellar spin on shaft not very often.
