MM 6cyl gas or propane?
Goin Gold
02-04-2008 16:55:40
I was wondering what peoples opinions are between running gas and propane...I know there are several MM's out there running propane and those people seem to swear by it???
oliver77
02-04-2008 18:34:26
 Re: MM 6cyl gas or propane? in reply to Goin Gold, 02-04-2008 16:55:40
I've run the MM's on both gas and propane. I only prefer gas because I'm more familar with it. I say run whatever you are more comfortable with, you are going to be the one to have to tune it. The propane is cheaper but is also a little harder to get than the racing gas. Probably doesn't help, just my opinion.
jd b puller
02-04-2008 17:03:55
 Re: MM 6cyl gas or propane? in reply to Buck Owens, 02-04-2008 16:55:40
Propane can support very high compression ratios and I've heard you can "hide" stuff to mix in the fuel for more power.
