losing weight
magg
02-03-2008 16:19:57
Will the hollow front end off a early WD fit a WD-45 ?? need to shed a few pounds...thanks ...Marvin
mlpankey
02-05-2008 17:42:39
 Re: losing weight in reply to magg, 02-03-2008 16:19:57
i should have added every pound of weight i removed from the front of my wd .i found myself adding it back to keep front end down . i tell myself it was worth it because now its farther out from the rear axle but i could be just justifying my efforts .
mlpankey
02-05-2008 17:33:49
sawing the back off flush to the steering bearing housing cuts 50 lbs youll loose the rod to manually crank the engine also. early wc has the lightest pedastal
alliswd45
02-03-2008 16:24:38
IT should, frame rails are the same width apart
