http://www.edmundantiquetractorpull.com/
long hauuler
02-02-2008 17:01:21
well just got my new rims and put on a set of firestone deep tread on them and ready to pull it to see what it will do. sound real good.
yankee2
02-03-2008 05:41:12
 Re: http://www.edmundantiquetractorpull.com/ in reply to long hauuler, 02-02-2008 17:01:21
what size tires. what size tractor do you have. what class do you pull in
long hauler
02-03-2008 11:00:00
 Re: http://www.edmundantiquetractorpull.com/ in reply to yankee2, 02-03-2008 05:41:12
1950 jd g 15.5 tires on 14" rims 6500lb to 7500lb. dont think theres enough power for more than that stock.
yankee2
02-09-2008 04:00:34
 Re: http://www.edmundantiquetractorpull.com/ in reply to long hauler, 02-03-2008 11:00:00
i think i know you if you got a red ford truck your tractor sounds like it has plenty of power i think all you needed was some traction because you spin to much. i hope the new tires helps you good luck
Dangerous
02-03-2008 15:03:44
Im a comin to this new pull in Lexington County and eatin you Green 2 bangers for snacks!!!!! !!!! In Ga. Green is the same thing as!hit.
long hauler
02-03-2008 16:30:12
 Re: http://www.edmundantiquetractorpull.com/ in reply to Dangerous, 02-03-2008 15:03:44
what kind of tractor is going to eat all the green stuff. feeding it spinach
yankee2
02-09-2008 04:03:29
 Re: http://www.edmundantiquetractorpull.com/ in reply to long hauler, 02-03-2008 16:30:12
he needs to come and show us because green is in
The Dukester
02-03-2008 12:16:46
Well, if your G is "pumped a little" with gas pistons, a little (.150-.200 in.) shaved off the head and some tuning tricks applied, it ought to be able to turn those tires in second on an average track and real decent in low on any power track @ 7500 lbs. If the G is still stock but in good shape it can turn those tires okay in low at 6500 lbs. Gotta have the G running good or you'll be embarrassed off the edge of the earth. There's a lot of competition at these weights so get ready for a learning experience.
