Input shaft on M
mshultz
01-30-2008 04:24:28
We're planning to put a double disk clutch in one of our M's (has DT407+ in it). We want to keep the pressure plate face at the same location so that the clutch linkage works the same, and just make the flywheel deeper to make room for the floater plate and clutch disks - there should be enough room for this.
The problem I see is that once we go deeper with the flywheel, the splined input shaft from the M won't be long enough to reach the pilot bearing. We haven't ordered clutch disks yet, so I'm wondering if anyone knows of a place to get a custom input shaft made, or if there is another tractor with a longer input shaft that we could use in it? I'd think we could turn the end down for the pilot bearing with no problems, but the other end would need to be at least close to make work.
Thanks for any input!
Cliff S
01-31-2008 20:22:31
 Re: Input shaft on M in reply to mshultz, 01-30-2008 04:24:28
Thanks Mike! No new E-Mail Yet Shaggy But i will Call you sometime this weekend and let you know more! Sat nite is Anties forts bankuet, I need to go i think i won 3 classes with the Super C!
turbos10
01-30-2008 20:29:32
I run a billet flywheel and hayes double disk slipper in my M. I also run the factory spline shaft and clutch linkage. One thing to consider is the arm length and travel on the stock versus slipper. With stock linkage there is only about 1/2" travel in the pedal from free to engaged. It will push in further but is not needed. My point is that this may allow you to move the pressure plate back. Shoot me a mail if you want some measurements.
ChadS
01-30-2008 07:36:42
I think I can help you with that. call Earl, 574-893-7437. You might get away with a slip over coupler,,, that slides over the stock M splines and has the OD splines to what ever you had, or had made,, and make the coupler, longer to reach back farther?? does this sound possible?? But we can cut the splines, for sure. ChadS
Cliff S
01-30-2008 15:55:04
 Re: Input shaft on M in reply to ChadS, 01-30-2008 07:36:42
Hey Mike, Ive moved and losted my MAFMCA Bankuet info, When is it? and when do they need to know by? Thanks Cliff S
MJF
01-30-2008 19:39:58
 Re: Input shaft on M in reply to Cliff S, 01-30-2008 15:55:04
Hey Cliff the banquet is Feb 16th, RSVP by Feb 8th
ShaggyM
01-30-2008 17:59:34
Hey Cliff!
Do you have a new Email? I was going to call you this weekend but it was a little crazy.
Drop me a line!
Mark
mshultz
01-30-2008 16:57:40
Cliff,
Not sure about the date.... around the 13th-ish?? I think they need to know by the meeting next tuesday - at least that"s when I plan on putting our numbers in.
Mike
