JDB
JDG70
01-28-2008 14:16:15
I was wondering how big of rod journal you could put in a B stroked to 7". I"m not sure what the guys are using out there.
jd b puller
01-29-2008 20:09:18
 Re: JDB in reply to Bob-Wyo, 01-28-2008 14:16:15
JDG70, I guess, to accurately answer your question, as asked.... One of the most popular combinations out there is a PowerBlock +0.125" which would be 5.125" with a 7.5" crank and 2.300" (Farmall 300) rod journals (309 cubes). But there's plenty of room to go bigger with the journal as indicated in my earlier post below. The next one I'm building is 6.125" bore x 7.5" stroke with the 2.625" journals (442 cubic inches).
jd b puller
01-28-2008 20:34:02
 Re: JDB in reply to JDG70, 01-28-2008 14:16:15
What year B is it? If it's 41-52, and you're only going 7", you can go at least 3". Suggest going 7.5" stroke x 2.625" journal. That way if you want to put a big bore in front of it, say, 6" or more, you'll have plenty of journal in there to do it with.
JDG70
01-29-2008 05:30:08
 Re: JDB in reply to jd b puller, 01-28-2008 20:34:02
I had thought about using a 4020 rod with the offset cap. the 2.625 journal is that out of an H. I think there is a certain ford rod close to that size.
thanks
jd b puller
01-29-2008 05:44:58
 Re: JDB in reply to JDG70, 01-29-2008 05:30:08
I'd stay away from the H rod, I'm thinking it's a sraight rod like your B. There's a Waukesha 320 rod that should work good if you go 2.625". It's an offset, which you'll need to stuff er in there. Haven't used the 4020 rod, hear a lot of guys with A's using a "329" rod.
Mike n Mo
01-29-2008 19:35:00
 Re: JDB in reply to jd b puller, 01-29-2008 05:44:58
I've used the "329" rod in A's, but would suggest going to a 3" journal if using anything bigger than 6.125" bore. Just be real particular about who welds up the rods if you don't use a billit rod. I've seen some ugly ones I wouldn't trust in a lawnmower. For a B, the 2.75" 329 journal should be ok and give good reliability. Mike
