Please help me make me a puller out of My Massey 30
mh444
01-26-2008 18:49:52
Does anyone know how much you can bore this continental 162 out and make it run I mean really run or know of some that could help me with this tractor. Know of someone that builds these motors up thanks
massey333
01-27-2008 07:10:48
 Re: Please help me make me a puller out of My Massey 30 in reply to mh444, 01-26-2008 18:49:52
You didn't say what Div.you are aiming for.Back in the early 60s when we still had ties with the right people in Massey and Continental and had a Jr.162 that we had owned since new and was a perfect engine run back thru engine fact.assy.line and made into a Gray Marine engine,bored .60 over and able to run 6000 RPM.It was a hot little engine but wasn't much better to farm with or pull when you were limited to 22-2300 RPM.On 20" drawbar 3500 was tops,4-4500 on 18" drawbar.I would be leary boring one out that far now(Pitting walls) unless you are planning to sleave it anyway.I don't think you are going to find any of the Gray Marine stuff now unless Montes has it.Lastly,in Div.2 I could hold my own with the A-Cs most of the time. Good Luck and Good Luck.
JDH
01-27-2008 05:05:43
I would suggest putting a H260 or H277in it from a 44. The sheet metal should be the same. I think it bolted in the original holes. I'm sure there are more parts available for those.
MH55
01-27-2008 07:11:43
 Re: Please help me make me a puller out of My Massey 30 in reply to JDH, 01-27-2008 05:05:43
Sheet metal was different from a 30 to a 44, grill is taller in a 44 and the exhaust hole is in a different spot, fuel tank is also bigger i believe. I f yo put a 44 engine in the 30 most clubs would make you pull as a 44 which would pull you up out of the lighter weight classes. A 30 should be able to pull in the 3500lb class with some stripping, have seen a 33 in 3500 class and the F162 is a physically smaller engine then An E201. As far as building a 162 I 'm not sure what they are using but there is A piston that fits the rods and will bump the cubic inch to 199-200 range without stroking. Put a better cam in from a marine or generator application and go have fun...
