miss firing
outlaw biker
01-26-2008 11:10:58
put new cap on when it was miss firing,using a msd coil . still does same thing as the old one. is it another bad cap?
outlaw biker
01-29-2008 06:28:27
 Re: miss firing in reply to outlaw biker, 01-26-2008 11:10:58
it seams be just when I start tractor,rpms about1900 . I will change points.
Mike Layden
01-26-2008 14:15:28
Just read your post I'm not sure what kind of RPM's your turning but I know we once had a race car that kept misfiring at top end it turns out the points were rated for something like 7000 rpm's we were turning more than that points couldn't keep up put a new set in rated at higher rpm's and fixed the problem check the package it should say what rpm's they're rated for Hope this helps
CENTAUR
01-26-2008 12:07:44
I would look some where else If the points are in good shape I would pull the plugs next.If one looks fouled transpose it one from another cylinder.and see if it burns away.Does it miss when under no-load idle?Are the points opening as they should? CENTAUR
