PUTTING A 350 IN AN M
NEWBEE2
01-25-2008 15:45:28
WHAT DOES IT TAKE TO PUT A CHEVY 350 INTO A FARMALL M?
mrbillsmolines
01-28-2008 13:09:04
 Re: PUTTING A 350 IN AN M in reply to NEWBEE2, 01-25-2008 15:45:28
I've got a massy harris 30 set for a 350 I'll sell you just needs finishing.
mngopher
01-30-2008 15:20:53
 Re: PUTTING A 350 IN AN M in reply to mrbillsmolines, 01-28-2008 13:09:04
I am interested in the MH30. Send me an e-mail with [email protected]
Ian Johnsen
01-27-2008 15:08:41
Put a chev 350 in a Massey Harris 44 or 55. The clutch housing is divorced from the transmission, so the combinations are endless. The 44 has a bolted coupler and the 55 has a chain coupler. I have built one of each with great success. the RC 44 has a loger frame and wheel base, and you can even put a four speed behind the motor. That's 20 gear choices between the two trannies and you can use SFI approved clutch parts and bellhousing for safety. Run a good SFI approved balancer as well. Good Luck.
johndeereman
01-26-2008 17:57:06
we had a farmall f-12 with a ford 406 in it we used the ford clutch set the motor ahead a little and run a drive shaft to the input shaft on the tranny of the tractor that was one awsome tractor was built to blow haylage up a 120 foot ribstone could do so with ease also would run 50 mph down the high way so pulled hay wagons with it too way too light in the front end though
Eddie Haskell
01-26-2008 09:34:48
WHY!!!!! !!!!! !!!!! !!!!! !!!!! !
ChadS
01-26-2008 08:31:53
Chevy LS2, with a single turbo. Never seen one of those yet. Chad
Charles E. McNelly III
01-26-2008 10:08:01
 Re: PUTTING A 350 IN AN M in reply to ChadS, 01-26-2008 08:31:53
Why just 1 turbo :)
ChadS
01-27-2008 15:41:43
 Re: PUTTING A 350 IN AN M in reply to Charles E. McNelly III, 01-26-2008 10:08:01
2 would be too much! LOL!!! Just the sheer awe to see a efi setup in an old antique.
chevyman
01-26-2008 06:15:41
put a duramax in it.
Andy Motteberg
01-25-2008 21:21:08
What are you going to do with the old engine?
NEWBEE2
01-25-2008 22:02:15
 Re: PUTTING A 350 IN AN M in reply to Andy Motteberg, 01-25-2008 21:21:08
The tractor that I'm using was used as a parts tractor I picked up for just nothing becuase the head was off the engine, had to disconnect the shaft between the engine and x-mission just to get it to roll. I've been soaking the engine for a few months and hopefully will try to overhaul it next winter.
Andy Motteberg
01-27-2008 10:56:53
 Re: PUTTING A 350 IN AN M in reply to NEWBEE2, 01-25-2008 22:02:15
Are you going to put it back in the M after it is overhauled?
BINDER DOG
01-25-2008 20:15:44
WITH SAFETY ALWAYS A MUST, YOU SHOULD NEVER USE A SPACER FOR YOUR FLYWHEEL!
PLEASE HAVE A FLYWHEEL MADE TO FIT YOUR APPLICATION BECAUSE ITS NOT WORTH SOMEONE DYING OVER WHEN IT COMES OUT OF THE CENTER SECTION OF YOUR TRACTOR JUST BECAUSE YOU WERE TO CHEAP TO PUT IN A GOOD FLYWHEEL!
460/560
01-25-2008 21:40:54
 Re: PUTTING A 350 IN AN M in reply to BINDER DOG, 01-25-2008 20:15:44
You can use a spacer and it will work fine if its done right. I would recommend getting the whole assembly balanced though to ensure everything is true. I know of several guys using spacers that are running alot of rpms and making alot more torgue than a 350 will.
NEWBEE2
01-25-2008 22:03:19
 Re: PUTTING A 350 IN AN M in reply to 460/560, 01-25-2008 21:40:54
When balancing do I need to have it balanced to zero?
460/560
01-26-2008 10:07:51
 Re: PUTTING A 350 IN AN M in reply to NEWBEE2, 01-25-2008 22:03:19
I don"t believe you would want to do this on your own. I took my flywheel to a machine shop that had the abilities to balance it . Its alot like balancing a tire as far as the process, except they remove weight instead of adding weight.
BINDER DOG
01-25-2008 20:10:46
NEWBEE2
01-25-2008 21:08:27
 Re: PUTTING A 350 IN AN M in reply to BINDER DOG, 01-25-2008 20:10:46
WHAT ARE SOME SPECS THAT I NEED TO START WITH? OR IS THERE A SITE OUT THERE THAT CAN HELP ME GET STARTED?
THANKS,
NEWBEE2
01-25-2008 21:06:58
CAN A MACHINE SHOP FABRICATE A FLYWHEEL FOR ME OR IS THERE A PLACE THAT I CAN BUY ONE TO BOLT ON? CAN I HAVE MY M FLYWHEEL FABRICATED TO WORK? I'M JUST LOOKING TO GET POINTED IN THE RIGHT DIRECTION HENCE THE NAME. ANY SUGGESTIONS/TIPS ARE WELCOME. I REALLY APPRECIATE THE SAFETY TIP BINDER DOG.
THANKS,
Drew
01-26-2008 16:58:40
 Re: PUTTING A 350 IN AN M in reply to NEWBEE2, 01-25-2008 21:06:58
DO NOT make an "M" flywheel fit the SBC. The "M" flywheel was made for an engine rated at 1600RPM. Even if you dont get crazy, you will turn the SBC atleast 2x that, and maybe even 3 or 4x the RPM that flywheel was intended for.
Joe H.
01-25-2008 16:53:42
time and money!!!!! I have a 440 dodge in a M just remember 11" clutch will work
on my 440 I had a flywheel spacer made and spaced it back 1 7/16" And used the dodge flywheel and pressure plate and used a special 8 pad "M" disk a little fancy throwout bearing work and their it is any more ?s e-mail me and we will talk
mn dave 2
01-26-2008 17:58:40
 Re: PUTTING A 350 IN AN M in reply to Joe H., 01-25-2008 16:53:42
I also have a chrysler 440 that I installed in a M about 2 years ago. I had a complete new steel flywheel made to the orig cast size so that I can use the orig starter.
I had the same machinist true up the orig adapter plate so that I could bolt new motor in the same way old motor was. I did not have to widen or stretch the frame rails to get motor to fit in, but did have to grind a lot. I bolted motor in and then welded front motor mounts to frame rails.
You will have to use electric fan as new motor will sit a lot lower in chassis than orig.
I used a pressure plate from a ford diesel pickup and am using a heavy duty clutch plate from a M (splines will be same a input shaft into orig transmission/rear end- which I use).
I have 18.4x38 cut tires on, I pull at 6000 rpms (I use a MSD 6AL rev limiter as a governor) in 2nd gear which is 12-14 mph pulling a sled. I have a estimated 400+ hp (no way to check for sure). I pull in 5000# to 7000# open, tractor with me on weighs 4800#.
I have been down track 39 times with this tractor and trophied 36 times with 3 DNF from mechanical problems. The only problem I have with this tractor is all the whining from the open pullers who used to kick my butt on a regular basis with my other tractors and now find it easier to complain. I guess that it would be more "fair" in their minds if I had spent $25000 on a hot motor and then "appeared" stock, (I have less than 8k in tractor).
I have some pictures and some video that I haven't tried to post on here, maybe my wife can if I ask her nice.
There is a gentleman with a 420+ci 460 and another with a 800+ci MM that are both exremely tough, we take turns beating each other. GREAT competition and not afraid to pull against me!!!
If you need more help, just ask.
