MM GVI
Newbie Puller
01-21-2008 18:35:02
I would like to build an MM GVI. Im not sure where to start after buying the tractor. I would like to build one for our 6 mph class. I always hear something about an HD-800 engine but Im not sure what that is? Any help would be appreciated.
Yellow Rocket
01-25-2008 09:34:09
 Re: MM GVI in reply to Newbie Puller, 01-21-2008 18:35:02
I have a short block 825 cube motor for sale.
Give me a call.
1 715 536 6779
Ask for mike
oliver77
01-22-2008 10:03:06
The 800"s that came as dealer options in the tractors were small bellhousing motors. They would not be a "bolt in" engine like the older 800"s. Not to mention that they cost considerably more to find and buy.
oliver77
01-21-2008 19:42:11
A HD800 is a MM power unit that was originally built to run off of LP gas. It was mostly used as a well motor in the midwest. If you get an early 2 piece rear main seal motor all you have to have to bolt it in a GVI is a diesel flywheel off of the GVI. A good 6 mile motor won"t matter if you have 4228 or 4229 heads as both will be more than enough hp. If you"re going to go faster the 29 heads make more compression from the factory.
ollie 88
01-22-2008 05:48:39
 Re: MM GVI in reply to oliver77, 01-21-2008 19:42:11
I'm pulling a GVI with a 605 motor. Was this also a irrigation engine? Thanks.
Newbie Puller
01-22-2008 18:21:48
 Re: MM GVI in reply to ollie 88, 01-22-2008 05:48:39
So what would be the best engine-head combonation?
dobber
01-22-2008 09:23:01
Yes, 605 & 800 were once common for large power units or irrigation well engines ran on LPG or natural gas. MM put a 800 LP in the 4x4 A4T tractor from the factory and some MM dealers put them in G1000 series also out to farmers.
