Power of a stock G
GoJDpuller
01-19-2008 08:14:09
What does a stock G usually dyno? I know they were rated at 38 but thats not much more than a A.
hot rod A
01-23-2008 10:27:08
 Re: Power of a stock G in reply to GoJDpuller, 01-19-2008 08:14:09
A good running but stock G should honestly dyno in the mid to high 40s with no problem at all. You"ve gotta remember that the 38hp number for an A was on gasoline, while the only Nebraska test for the model G was on the distilalate/kerosene fuel. Look at the tests on a 70, which is essentially the same engine as the G, there"s nearly a 10 hp difference when you go from kerosene to gasoline. The G came with about 90 cubes more than the styled A, you can"t tell me that 90 cubes is only good for about 1/2 a horse!
agree......
01-20-2008 20:26:19
you should have anywhere's from 42-48 for a good gas G with a gas manifold and all. got a relitive that has a 50's G with 6.125 aluminums and the big swirl head and it dyno's 54-56 everytime anyday. ask 2cyl. about old don's G...he still wins once in a while with it in speed limit classes.
jd b puller
01-20-2008 18:49:27
 Re: Power of a stock G in reply to BARNSLEY, 01-19-2008 08:14:09
On a given day any tractor could outpull another. Depends on the weight class as well, if you had the G stripped to the gills and had a Farmall H weighted correctly, the H could win. Yes, the G has more HP and torque than the JD A, but there's a balance there of HP, tires, weights, ability, etc...
GoJDpuller
01-20-2008 17:46:26
So would a stock G out pull a stock A? With a bigger stroke I would think a G would have more torque and out pull the A.
2 Cylinder
01-20-2008 06:28:35
They maybe some what of a gutless wonder in stock, all fuel form. But with a set of Aluminum High Compression Pistons, and a Flat Head, along with removing the needless baffles in the manifold you will dyo at 65-70 horsepower.
gggg
01-22-2008 16:40:41
 Re: Power of a stock G in reply to 2 Cylinder, 01-20-2008 06:28:35
Hey email me w/your phone number as I would like to discuss power in my JD G.... As I have ?"s... THANKS
ollie 88
01-19-2008 17:30:29
Many years ago my stock 51 G dynoed @ 35 hp. It was truly a gas guzzlin gutless wonder.
bigjohn 3
01-19-2008 09:59:21
A stock G will pull 32 - 36 hp on honest dyno. Low output for large cube engine.
Dangerous
01-20-2008 11:42:08
 Re: Power of a stock G in reply to bigjohn 3, 01-19-2008 09:59:21
What Deere series do you have Big John?
bigjohn 3
01-20-2008 13:25:56
 Re: Power of a stock G in reply to Dangerous, 01-20-2008 11:42:08
JD 4650.
