ChadS
01-19-2008 07:48:17
Re: Farmall H upgrades? in reply to TimWafer, 01-19-2008 07:06:54
Tim, our 350 row crop has a left handed cam nut. and the part number you mentioned is correct. Dead giveaway for ID is the left handed cam nut. (If the part number is not ledgeable) should be used when a live hyd pump is used. 8043D? series gas head are good cyl heads, 8043DD are the Super H heads, replicas of the 300-350 gas head. If the domes on the pistons are much over 3/8" tall, just shave enough off the head to make it flat. Have a look at the lifters, if you find a regrind puller cam, find lifters to go with it. Rocker arm tips should be resurfaced, check the whole valve train for wear, replace anything that looks bad. 350 distributor housings had a cable tach drive, so maybe you could find a custom tach and mount it somewhere. 300-350 timing cover with a live pump, and plumb it up from there. 6 volt starter might not turn it over,,,,
That recipe sounds like a good one to me. I have a 3.5 overbore Super H, with firecraters, and its a fun little machine, work or play, was thinking of adding live hyd to it too. ChadS [email protected]
