pistons
jesse allen
01-17-2008 19:33:13
I have a john deere 60, and im trying to gain some compression. Ive shaved my head .250 thousandths but still only have around 100 pounds of compression. I have around .575 thousandths still between valves and pistons. Could i get a .5 inch plate of alluminum welded onto head of piston, then machine down smooth to gain some compression?
52 G
01-20-2008 11:15:08
 Re: pistons in reply to jesse allen, 01-17-2008 19:33:13
I've got a 53 model 60 with high comp. pistons no head shaving or anything else and it has 145 psi, There must be something else wrong not building compression.
mlpankey
01-19-2008 18:48:39
not familar with deere. but i know that even the molded lines on high compression piston have to be sanded down or hot spots occur . i would think bolt heads through piston deffinetly would cause hot spots maybe even pre detination.
james rumph
01-19-2008 05:01:59
I don't know deers but with that much removeal of material off the surface of the head !On a farmall you end up making spacers of the same thickness to go under the pedestal of the valve train to keep adjustment correct .
We had a "M" head with .125 removed and with out .125 spacers it was almost out of adjustment and the valves were not closing [ low compression]. Does this play a roll on this as well ? It's the simple things that bite us in the butt !
old ollie
01-18-2008 18:24:12
a good team of mules would solve this problem & have more power
jd b puller
01-18-2008 14:08:38
 Re: pistons in reply to bob smith, 01-17-2008 19:33:13
Thanks Drew, If my numbers are right, he should be at 9 ish :1 compression right now. should be reading a lot higher than 100 psi. did you redo the head when you milled it? Cam off a tooth, valve leaking, rings didn't seat, something is amiss....
By the way, if you install a 1/2" plate on the top of the piston you'll be over 20:1 compression...
jesse allen
01-18-2008 18:35:19
 Re: pistons in reply to jd b puller, 01-18-2008 14:08:38
Would it even run on that 20:1 compression ? What octane gas would it take ?
jd b puller
01-18-2008 13:14:44
 Re: pistons in reply to Lamont, 01-17-2008 19:33:13
Difficult to tell compression without a good measurement for cylinder head combustion chamber volume.
Assuming flat top pistons,
- If head is 15in^3, you'd be at 6.7:1 and 1/2 plate 5.5" in dia would get you to 10.75:1 (a tad lower thatn this as you'll have to notch for spark plug)
- However if head was 20in^3, you'd only be at 5.9:1 and 1/2" plate would get you to 8.5:1.
I don't have a A head here to measure, B head was about 7 in^3 with 0.100 milled off.
Drew
01-18-2008 13:24:20
 Re: pistons in reply to jd b puller, 01-18-2008 13:14:44
I think a late A head has about 11.25in^3. I think a 60 head is the same or maybe a tad less volume.
Mike Aylward
01-18-2008 18:45:40
 Re: pistons in reply to Drew, 01-18-2008 13:24:20
Drew, the 60 head is tighter. I'm not sure of the cubic inches but the head gave the 60's about a half point more compression. If memory serves me right it's about a quarter inch less chamber. Mike
jd b puller
01-18-2008 10:25:53
Jesse, you should let it crank over 1/2 a dozen times. Both plugs out, full throttle, no choke (engine NOT running).
- how far is the piston from the top of the BLOCK?
- any idea what the combustion chamber volume of the head is? I was thinking it was around 12-13 in^3 before you milled it down.
jesse allen
01-18-2008 11:48:11
 Re: pistons in reply to jd b puller, 01-18-2008 10:25:53
the piston stops .5 inch from end of block. What compression ratio should i be running with the milled head?
730-LP
01-18-2008 10:14:30
Jesse take both plugs out,open wide open and check comp.on each cylinder,remove breather from carb and re-check to see if you have a restriction in air flow
oliver eater
01-18-2008 06:18:49
i bet if you welded a red piece in it would pull alot better id say a stock 400 farmall from hodge farms would beat a 60 anyday
Mike n Mo
01-17-2008 21:15:02
You may have other problems to deal with. A stock 60 should have around 120 psi assuming ring seal is good and valves/seats are sealing properly. What pistons are in the tractor? I assume you do have the throttle completly open when doing the compression test?? Mike
jesse allen
01-18-2008 08:48:41
 Re: pistons in reply to Mike n Mo, 01-17-2008 21:15:02
It has been bored .045 over with m and w high compression pistons.I was told when you test the compression you are supose to leave the switch off and turn the motor over twice , then read the gauge. Are you supose to test it with the motor running in the full throttle posistion?
BushogPapa
01-18-2008 19:23:01
 Re: pistons in reply to jesse allen, 01-18-2008 08:48:41
Nothing less than TOP NOTCH Valve work will be good enough.... NEW rings must be put under a GOOD LOAD within 15 minutes of starting the engine or they will not seat properly..if not, pull the pistons and re-hone the cylinders and try again..
Let's see...a stock "Gas 60 has 6.1:1 Comp.. With the +.045 M&W's, maybe 6.5, not over 7:1 Now, with .240" removed..you should be in the "HIGH OCTANE" territory, for anything requiring it to actually "Work" for a living..!!
What do you say guys, is he OVER 9:1...?? (That's pretty High for a farm tractor)..!!
Bet it will sound pretty at an idle...!!
Ron.
jd b puller
01-17-2008 20:29:44
 Re: pistons in reply to jimmy77, 01-17-2008 19:33:13
You can BOLT a piece of plate in there. Trust me on this one...
Don't just willy-nilly stick a piece of 1/2" in there. CC your cylinder head and do the math to determine the thickness you need.
jesse allen
01-17-2008 20:51:54
 Re: pistons in reply to jd b puller, 01-17-2008 20:29:44
Well before i shaved the head i put .800 thou thick of playdough on my piston, turned it over and it never hit the valves. Had head shaved .250 with .010 thicker head gasket. So really .240 gone. So that leaves you .560 thousandths to go. So should be fine. Do you mean drill and tap my piston, and bolt it on?
Phil Munson NY
01-18-2008 08:09:13
 Re: pistons in reply to jesse allen, 01-17-2008 20:51:54
Jesse:
Pay attention to what this gent says; he really knows his two cylinders. Having made such a radical change in the head, a sigificant increase in compression should have been noted. The lack of such an incease makes me think that perhaps other problems; ie rings, valves, porting, need to be investigated. best, Yeoman
